Remote hatch question
Old May 26, 2006 | 01:14 AM
FireBirdKnight's Avatar
Car: 1985 TransAm
Engine: 5.0L TPI
Transmission: 700R4 auto
Axle/Gears: 3.27 BorgWarner
my car didnt come with remote hatch but was an option that year I was curious if the wiring would be in the car still but just not used? so i could hook it up
Old May 26, 2006 | 01:20 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
should all be there. it is on the birds. i added a remote hatch release to my 1986 2.8L bird.
Old May 26, 2006 | 01:23 AM
Car: 1985 TransAm
Engine: 5.0L TPI
did u just open up that plastic dash cover and there was a open connector?
do i need to hook anything up to the rear hatch motor too?
Old May 26, 2006 | 12:47 PM
82 Iron Duke's Avatar
Car: 04 Silverado
Engine: 4.8
Transmission: auto
Actually all you would have is the plug underneath the center console. You need to get the release or motor, the wiring, the solenoid, relay, switch etc to make it work.
Old May 26, 2006 | 01:02 PM
Car: 1985 TransAm
Engine: 5.0L TPI
i heard a horn relay works i have a few of em but where does the Realy go? can u support a pic of the relays location thats my main Q
Old May 26, 2006 | 01:16 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
I can, but I would have to dissasemble my center console. I will do it asap
Old May 26, 2006 | 01:50 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
OK, I couldn't find my camera so I will do my best to describe it. Under the center console you should find a set of brown and orange wires with a female plug at the end. You will need the relay housing, on one end of the housing is a set of a yellow and orange wires that has a male plug, which plugs into the female under the console, out of the relay housing is another set of wires orange and brown that plugs into the switch. Now the relay is small and black and I got the # 329820 off of it. I hope this helps.
Lawrence
Old May 26, 2006 | 02:48 PM
Car: 1985 TransAm
Engine: 5.0L TPI
i found the connection for the switch but not the relay.... looked very hard too if someone can get a pic and step by step insturctions it would be much appricated
Old May 26, 2006 | 03:34 PM
Car: 04 Silverado
Engine: 4.8
Transmission: auto
You won't find the relay, you have to have the complete wiring from a donor car that has it. It runs from the center console to the hatch release, I installed it when I did my interior swap, carpet and everything removed from the car.
Old May 26, 2006 | 03:36 PM
Car: 1985 TransAm
Engine: 5.0L TPI
i found the relay housing but no wires so i guess im not even gonna waste my time
Frozer!!!
Jan 19, 2024 04:55 PM
jbates346
Car Audio
25
Jun 10, 2020 08:27 PM
Vintageracer
Jan 10, 2020 05:33 PM
madsv1000
Aug 20, 2015 06:45 AM
redmaroz
Aug 16, 2015 11:40 PM
