Apparent VATS problem, how to fix?
Old Aug 17, 2006 | 02:00 PM
92centexcamaro's Avatar
Car: 92 Camaro RS
Transmission: stock
Axle/Gears: stock
Ok so I took my car to get the 350 swap done a few weeks back. They finished and I was on my way home a happy driver of a new 350. Well, kind of. I used to have a starting issue every so often of the car not wanting to turn over. All the electrical would start right up ie. guages, radio, lights, ect. But when you went to turn the key that extra way it wouldn't try to crank. Nothing. Oh and the water temp guage would go all the way to the right?. Well after the swap it started doing this almost periodically. I was taking her home on the interstate and when I would get on the gas the rpms would go from 200-2000+ and back and forth real quick. Then BAM backfire and die out. They had ghetto rigged a battery ignition so you could pop the hood and crank her. Got it to crank but it would die right when you went to stop. Got it back to the shop and they ran tests that showed the temp sensor was sending whacky signals so the comp thought the temp was drasically changing causing very jumpy rpms and weird behavior by the car when driving. They had some guy who knows this kinda stuff come look at it and he said it was the vehicle security system that was causing all the problems. Said there was no real way to bypass it either. Said that was what was causing the starting problems(chip in key) and that it was causing the feul presure(i think thats what he said) to change alot like it was. So now I am pissed and desperate. I am fixing to have to call the guy who came and looked at it so I can find out how much it will be to fix it. Can anyone tell me if they know what is wrong with it so I don't get ripped off, or maybe I can go replace a part on it so I dont have to get them to work on it. Also the temp sensor doesnt make the fan come on, its not wired right I think. I had the fan running to the radio fuse in the fuse box inside the car so when the key was turned the fan would run.
Thanks for any help, im desperate. Also this got progressivly worse until the car wouldnt crank at all. Can I safely bypass VATS? Will it work? Pics if so please. DETAILS too(lots).
Old Aug 17, 2006 | 08:52 PM
cadman277's Avatar
Car: 95 z28,86 iroc
Engine: 350 lt1,305 tpi
The vehicle theft system has nothing to do with how the engine runs{ounce the ecm recieves a signal to start from the key-theft system} eveything should function accordingly,you seem to have a another problem.
Old Aug 17, 2006 | 09:06 PM
livewire's Avatar
Car: 1983 Z/28
Engine: Edelbrock 355
Axle/Gears: 3.42/Zexel/PBR
Like said above it has nothing to do with how the car run s, just allowing it to start. it is a rather simple theft deterent and it is very easy to bypass if you have the original key.
Old Aug 17, 2006 | 09:57 PM
Car: 92 Camaro RS
Transmission: stock
Axle/Gears: stock
Ok if its not VATS then what could it be? It IS having trouble starting. Its not turning over at all. It was giving the symptoms of something wrong with VATS acting up. (searched for problems with VATS on site). Also I thought I read VATS can regulate fuel comming out of the injectors?
Old Aug 18, 2006 | 05:15 PM
Cooper's Avatar
Car: '89 GTA
Axle/Gears: 3.45
The vats module sends a signal to the ECM to enable the injectors on start up. Once the car is running vats is not an issue.
If it's not cranking, that could be a vats issue. Does your security light come on when you try to start it and it doesn't crank? There's only so many things it can be if it's not cranking at all ~ starter, battery, solenoid, clutch or p/n switch, ignition switch, vats. I'd sooner think you have some loose wiring near the battery or starter.
Old Sep 1, 2006 | 08:23 AM
jgotthardt's Avatar
hey, i replaced my steering column in my 90 camaro RS. now my car will not start. i still have the column and key that i took out. how do i bypass this system please please!! i need to get on the road. Thanks!!
Old Sep 5, 2006 | 10:35 PM
jerryh361's Avatar
Car: 1991 Firbird
Engine: 3.1 liter
Transmission: automatic
Axle/Gears: i have no clue
same problem here
i have a 1992 firebird 305 tbi well itll run fine till under 1400 rpm's and sputter and die rpm jumps up and down before dieing unless i can catch it in time and gas on it. i checked the codes and only getting egr code and vats code.itll only do it every now and then. sometimes 3 times a day sometimes not for a month. any ideas??? but someone mentioned vats can be bypassed with original key. i have mine, hopefully someone can tell me how. im going crazy here almost to the brink of selling my fave car, has left me stranded at work several times and my job was a ten hour drive away. my name is jerry my cell in 361-655-0476 my email is monoxide_child80@yahoo.com feel free to hollar at me, i am almost never on the net so a call would be easyer thanks in advance. ~Jerry~
Old Sep 6, 2006 | 07:26 AM
8492bird's Avatar
Car: 84-92 firebirds
Engine: 2.8/3.1
Transmission: auto
https://www.thirdgen.org/forums/elec...ing-v-t-s.html
Check this thread.
Street Lethal
Apr 30, 2019 12:14 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
dyeager535
Aug 28, 2015 08:10 AM
theurge
Aug 21, 2015 12:46 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
