power window motor???
Old Oct 2, 2006 | 08:18 PM
david068513's Avatar
Car: 1992 z28/1992 RS heritage edition
Engine: 350 tpi, 305 tbi
Transmission: 700R4,T5
Axle/Gears: G92
in my 92 z28 i have the new motor but no rivit gun so is it possiable it just put bolts in the place of the rivits?
Old Oct 2, 2006 | 08:23 PM
FASTERTHANUMARK's Avatar
Car: 1970 Nova
Engine: 850HP 383
Transmission: TH400 w/ Brake
Axle/Gears: 4.88 12 Bolt
Yes you can do that.Most of the time when you buy new motors anyways, they come w/ nuts and bolts to attach them.
Old Oct 2, 2006 | 08:25 PM
Axle/Gears: G92
ok thank also do you know a easy way to get the door panel off without messing it up? how do you get the old rivits out?
Old Oct 2, 2006 | 08:26 PM
Car: 1970 Nova
Engine: 850HP 383
You have to drill the old rivets out.The door panel is easy to get off also.Just take your time doin as to not rip and clips off the cardboard around the outside of panel.
Old Oct 2, 2006 | 08:29 PM
Axle/Gears: G92
so the cardboard just pops off and then you can take the panel out?
Old Oct 3, 2006 | 05:57 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The upper portion, black plastic that runs the length of the door, can be a pain the first time. Roll the window down, push in and up on it at the rear of the door to pop the first fastener, then work your way toward the front of the door. Total of four fasteners, IIRC. Also, some of the torx head bolts on the plastic of the door handle/mirror area are fake. Use a magnet of you'll round them out (don't ask me how I know). Consider the following link:
https://www.thirdgen.org/forums/body...servation.html
JamesC
Old Oct 8, 2006 | 03:58 PM
Axle/Gears: G92
i confused i tryed to get the panel off and i think i did something wrong...i tryed pulling the black pastic off and it was connected to wood and little wood chips were falling out. what did i do wrong?
Old Oct 8, 2006 | 04:00 PM
Axle/Gears: G92
bump
Old Oct 8, 2006 | 04:13 PM
Axle/Gears: G92
i really need help now the plastic isnt laying flat like it was before...what did i do wrong? has this happened to anyone before?
Old Oct 8, 2006 | 09:04 PM
JamesC's Avatar
Apparently you didn't remove the panel correctly. Once the door panel is removed, you'll see that the plastic piece is secured to the panel, which is very heavy cardboard of some sort. Once the "nuts" are removed, the plastic comes off easily.
JamesC
Old Oct 8, 2006 | 09:06 PM
Axle/Gears: G92
well then how do you get the panel off?
Old Oct 9, 2006 | 05:45 AM
JamesC's Avatar
Remove arm rest and the plastic panel which includes the locks, mirror adjustment, etc. Pop the Christmas tree fasteners round the door's perimeter. Do as suggested above. Buy a manual.
JamesC
Old Oct 9, 2006 | 10:28 AM
Axle/Gears: G92
ok thank you for the info
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
neekolzun
Aug 24, 2015 04:59 PM
stalkier
Aug 13, 2015 12:59 PM
