Short in R.P.M and Oil Pressure gauges
Old Apr 10, 2007 | 11:09 AM
gawahl's Avatar
When I turn on the dash lights on my 84 Z28 my rpm and oil pressure gauges
short and read zero. I have removed the dash and the wiring and the circut
board look ok.If anyone has seen this problem before any help would be appreciated.
Old Apr 14, 2007 | 09:05 AM
pmpn's Avatar
Car: 1989 GTA
Engine: 5.7 TPI
Transmission: A4
Re: Short in R.P.M and Oil Pressure gauges
There is no short. Your switch (or any other light associated with that switch) is pulling too much power.
Old Jul 9, 2007 | 09:47 PM
BigBoi4Lyph's Avatar
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 9 bolt Borg Warner Disk Brake Posi
im having this same problem. i know my headlight/interior light switch is messed up the dimmer dosent work at all its either on or off. so would replacing my switch fix my gauges going 0 when interior lights are turned on
89GTAOz
May 16, 2020 09:31 AM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
