will it still crank over if vats box is bad?
Old Apr 25, 2007 | 05:18 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
i used my meter to measure key ,and wires when ignition key is in the switch.it all reads right ,however i'm getting no fuel to injectors.just wondering.it cranks over very well.
Old Apr 26, 2007 | 05:31 PM
fbodyguy86's Avatar
Car: 92 camaro rs
Re: will it still crank over if vats box is bad?
if the vats system is bad it may still crank the engine but it wont "fire" the fuel injectors you should still have fuel at the rail but not coming from the injectors if that is the case it would be a vats problem
Street Lethal
Apr 30, 2019 12:14 PM
Jae992
Aug 27, 2015 09:07 AM
Dialed_In
Aug 20, 2015 01:45 PM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
