Main fuses Keep Blowing
Old May 11, 2007 | 09:31 AM
scarello's Avatar
Car: 1991 Camaro RS Convertible
Engine: 305ci
Transmission: 4-Speed Auto
Hello All.
I have a 1988 Firebird that has the darndest condition.
The main fuse keeps blowing and the car goes completely dead.
The origninal owner thought it was the headlight actuator relay since he tested the plug to the motor and saw it had voltage.
I disagree with that assumption since even though the plugs to the motors were unplugged, the fuse would still blow.
Basically what I found is that when I hit a pretty good sized pot hole, the care immediatly went dead.
No power to anything.
Luckily the previous owner put in two (2) inline fuses off the positive post of the battery (30A) which I quickly replaced and was right back on the road. Only one of the fuses blew, so I guess I have to double check to see if each wire feeds different components or just go to the same place.
My guess is there is a bad ground or wire somewhere that is getting pinched and causing the failure.
Anyone else have any ideas or ways to try and isolate this issue?
Thanks,
Steve C - RI
Old May 11, 2007 | 09:40 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: Main fuses Keep Blowing
Main fuse? Do you mean a fuseable link?
I bet there is a positive wire going to the starter which is rubbed through.
Old May 11, 2007 | 09:43 AM
scarello's Avatar
Engine: 305ci
Yes.
If you look at the positive post, there are two fusable links he added that accept regular 30A fuses. After I hit the pot hole, one of the fuses blew and the car went stone dead.
I litterally just got the car last night, so up on the lift it's going. Hopefully I can find the short.
Steve C - RI
Old May 15, 2007 | 07:00 PM
scarello's Avatar
Engine: 305ci
EUREKA!!!!!!!
As nice as the OEM Stereo Cassette sounds, it was/is the culprit!!!
With the key turned on, if I slap the side of the dash to the right of the stereo, BAM!!!!
The fuse popped with one whack!!!
If I shut the stereo off (The clock is still displayed) and WHACK WHACK WHACK.... no fuse pop.
Go figure.................
Well, off to find a GM Cassette Deck for my '98
Steve C - RI
3rd gen money
Oct 11, 2019 09:57 PM
thunder57
Nov 7, 2015 02:28 PM
Fanatic1074
Oct 2, 2015 03:47 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
lanceflame44
Sep 25, 2015 12:28 PM
