need help plz want to keep the car
Car: 1988 Pontiac formula Firebird
Engine: 5.0 h.o.
Transmission: 5 Speed
Axle/Gears: 3.55 10 bolt
i got a 1988 formula firebird 5.0 5 speed i just put a new alternator in it and battery. the volt gauge says 11. i put a volt meter to the battery and it says 11.7 when running then i take off the ground from the battery and the cars dies. i checked a few of the grounds sanded them new terminals on the battery cables. what can it be plz help if i don't find the problem I'm going to have to junk the car
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
Re: need help plz want to keep the car
Sounds like the alt is not charging. Chech the plug on the side of the alt for 12V, it needs it to turn on the voltage reg.
Car: 86 firebird v6,86 corvette,88 GTA
Engine: 350 C.I.,2.8l.
Transmission: th700r4
Axle/Gears: 3:08,3:27
He means check the input voltage on the side plug with your volt meter.Although it may just be a bad alt. I've known people who went through 3 different ones before they got a good one.
Linson
Aug 21, 2015 02:12 PM
