Problem with Tach Wiring
Old Aug 20, 2007 | 08:33 AM
stevenb's Avatar
Car: 87 camaro
Engine: 357 swap
Transmission: t5
I found the tach wire (black with white stripe) and got it to go from 7000 rpms to 0 rpms by playing with it but when connected to the distributor it stays at 0 so do I have a bad tach in my dash cluster or is there something else I need to do to get it working? By the way, I have the IROC dash cluster.
Old Aug 20, 2007 | 09:16 AM
D3ATH)(TR00P3R's Avatar
Car: 88 Camaro SC
Engine: 305 TBI
Axle/Gears: Posi
Re: Problem with Tach Wiring
what kind of tach is it, also i think the tach wire is a white one, at least on my car ( 88 305 tbi) do you have a msd or electronic distributer? sorry i cant help much but if you give some more info it would help me( or anyone else)
By the way; Sweet engine!!
Oh i almost forgot. some tachs will require you to open them up ( vdo top eliminator) and flip some tiny swiches to set it for your engine type.
Old Aug 20, 2007 | 05:14 PM
stevenb's Avatar
Car: 87 camaro
Engine: 357 swap
Transmission: t5
I have the tach from the IROC dash cluster. Sorry, I have an HEI distributor. Would the wiring from your 88 be different from my 87? I was thinking it could be because of the difference in location from the stock 2.8 distributor locating comparing to the 350? Would color remain the same for the wire?
Old Aug 20, 2007 | 05:32 PM
redfire82's Avatar
Car: 84 camaro s/c
Engine: 305 slightly tweaked
Transmission: TH400
Axle/Gears: 3.42 single stripe
I'm having a prob with my tach too, when I connect the power and ground wires only it reads 0 as it should, but with the engine idling and connect a wire I ran directly to the tach to the distributor, the tach jumps to 6500 rpm and will peg out if the rpm is increased slightly. I've tried three junkyard tachometers so far.
Old Aug 20, 2007 | 06:35 PM
funkdubie's Avatar
Car: 85 z28
Engine: 355ci
Transmission: th400
tach wire is white...85 z28
Old Aug 20, 2007 | 06:37 PM
stevo the torpe's Avatar
Car: 91 maro
Axle/Gears: 373 locker
gray
Old Aug 20, 2007 | 11:30 PM
stevenb's Avatar
Car: 87 camaro
Engine: 357 swap
Transmission: t5
White or gray?
Old Aug 24, 2007 | 05:52 PM
mShock43's Avatar
Car: '83 Camaro
Engine: '72 350
I am also having trouble getting my tach to work on my '83 camaro. The tach worked for the 2.8 that was in it but when putting in a 350 with HEI distributor it just reads 0. If grounded is there a wire from the wiring harness that will make the tach work or will it even work at all? Any answers are appreciated.
eightsixseven
Dec 16, 2024 01:50 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
mustangman65_79
Aug 7, 2015 09:41 PM
stalkier
Aug 7, 2015 04:49 AM
