Fog Lights Won't Stay On!
Ok guys I need a little help.
The car 1990 GTA.
I replaced the Remote Dimmer Switch (hey I got dash lights now!!!)
Wired up the factory foglights.
Replaced the Fog Light Relay.
Replaced the 30 amp circuit breaker.
I've been checking and rechecking all the factory wiring with my tester.
Everything seems in order, power where it should be with the exception that the little lights in the fog light switch itself do not work.
When you press the fog light switch the fog lights go on but turn off as soon as you release the switch.
Should the rocker style foglight switch stay down or is it suppose to press and reset itself?
Has the switch itself gone bad?
I know you have to have the headlights or at least the parking lights on before the foglights will work
Thanks,
Dave
The car 1990 GTA.
Thanks,
Dave
Car: 87 GTA
Re: Fog Lights Won't Stay On!
Are you referring to the split rocker parking light switch? Or the lower fog light switch? On the fog light switch, there are 2 button...1 On, 1 Off. And the Off switch pops and stays up. I hate to say it, but are you pushing the Off one? It will pop right up.
Either way, they should stay down. I leave my fog light button pushed in 24/7. And just turn on the parking lights, which in turn powers the fog light switch, then turns on the fog lights.
Well I figured it out...some clown had the top rocker off the switch and put it back together backwards! I took the switch apart and seen the little spring loaded stops were not meeting the holes on the other side of the switch.
A quick flip and snap together and I have fog lights when I push the button!!! Woohoo! The rocker stays down completing the circuit. It pretty much took the whole day to fix and replace all the broken parts...not to mention the broken and spliced wires.
Anyway the search feature is excellent on this site and I found all the answers to my questions on old posts!
Great site!!!
Dave
PS. The one lilttle light works in the switch when the fog lights are on but the other one doesn't work when the dash lights are on...does anyone know where to buy replacement mini-lights?
Great site!!!
Dave
Great site!!!
Dave
Great site!!!
Dave
That was 10 years ago so I can't quite remember. I think I actually separated the switch itself as I was going to clean the contacts but I really can't remember now. But I did get them working. Good luck I chased my tail on that one for awhile.
Dave
Dave
