Dyno?
Old Nov 18, 2008 | 06:17 PM
British Rich's Avatar
Car: 92 Camaro RS
Axle/Gears: Stock
Dyno?
I did try a search...
Can anyone tell me what kind of engine TEMPERATURE readings a dyno can pull?
I assume it is a lot more than just the dash water temp right?
Thanks in advance
Old Nov 18, 2008 | 06:42 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Dyno?
What are you asking? The engine doesn't get any hotter on a dyno than it does in normal service.
Old Nov 18, 2008 | 07:12 PM
Car: 92 Camaro RS
Axle/Gears: Stock
Re: Dyno?
I mean, does the ECU track more than just the engine temp gauge we see on the dash? Or does it have feeds from additional temp sensors?
(I am assuming that for them to be useful at all you'd wanna read them on a dyno to simulate driving activity)
Old Nov 18, 2008 | 07:32 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Dyno?
The coolant temperature sensor for the ECM is a completely different circuit from the gauge sender. You don't need a temperature reading much higher than gauge's upper limit though, that's about the point that pressurized coolant starts boiling.
Old Nov 18, 2008 | 07:54 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Re: Dyno?
And there is yet another coolant sensor for the fan relay, which the computer does see but does not use for engine management.
TA
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
Nervous2
Oct 8, 2015 10:53 PM
LT1Formula
Oct 8, 2015 08:34 PM
BBSDesigns
Sep 22, 2015 03:08 PM
