Weird Blower Module Problem.
Old Dec 16, 2008 | 07:20 PM
Sly_dawg19's Avatar
I have a 88 firebird forumula 305 tbi.
Everything in my a/c / heater system works.
However... I got a small problem..
Lo
Med
^ Med high
O
High
this is a crappy rendition of our fan control on the dash.
When I am in Lo and High the fan blows the exact same, at a low speed
When I am in Med and Med High the fan blows the exact same, at a high speed
What could this be? Wrong relay? That is what I am guessing anyway.
Old Dec 16, 2008 | 09:21 PM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
Re: Weird Blower Module Problem.
The speed control resistors are under the hood in the heater box. Unplug it and make sure the wires for each speed are giving you full battery voltage. About 14 volts with the car running, 11 with the engine off. If the supplied voltage is o.k. I'd replace the resistor plate. Remove the 2 screws holding the plate down. There will be what appears to be different size springs on the other side of the plate.
The high running slow is odd as it is direct to the fan.
Old Dec 17, 2008 | 10:37 AM
Sly_dawg19's Avatar
ill try that when I get home, and ill post voltage numbers
thanks for your input.
Old Dec 18, 2008 | 10:39 AM
Sly_dawg19's Avatar
Well, didn't get to check the voltage, it snowed 8 inches in LAS VEGAS! So pretty cool day
Old Dec 18, 2008 | 11:36 AM
ACCLR8N's Avatar
Used to snow here in Michigan, but I've been dragging my feet on working in the cold garage on my project.
Old Jun 8, 2009 | 07:19 PM
Sly_dawg19's Avatar
Where is this resistor plate?
Old Jun 8, 2009 | 08:53 PM
ACCLR8N's Avatar
Under the hood on the passenger side of the firewall. See the picture in post #2. There is the flat wire connector going into it. 2 screws holding it in.
Old Jun 9, 2009 | 11:00 PM
Sly_dawg19's Avatar
they look fine, 4 pins on the top, and springs all coiled the the opposite sides of the posts on the back. it looks untouched and stock.
it is not my realy, i got a replacement one and worked the same way.
i am kinda stuck on this
to remind you, the low and high setting blow low. and the med and med high setting blow high. weird to me...
Old Jun 10, 2009 | 08:44 PM
Sly_dawg19's Avatar
FIXED, it was the control on the dash, i replaced it with a junkyard part and BLAMO, fixed.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
dusterbd
Sep 29, 2015 08:40 AM
tattmann
Sep 27, 2015 05:20 PM
