Which keyless entry?
Old Mar 10, 2009 | 08:57 AM
loopingz's Avatar
Car: 89 Camaro IROC-Z
Engine: 350 TPI crate
Transmission: 700 R4
Axle/Gears: 9 Bolts Borg Warner 2.77
Hi,
I am planning to add a keyless entry to my car.
If I buy a kit like:
http://www.customstreetdesigns.com/2202-KE-30.htm
will I have to add relays if I want a light and horn confirmation.
Anything else to think before to buy?
Old Mar 12, 2009 | 10:11 PM
loopingz's Avatar
Re: Which keyless entry?
No one with key less with some feedback?
Old Mar 16, 2009 | 09:16 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
You can wire the entry system to the headlight and horn relays presently in the car.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Fog lights are not driving lights. Keep em turned off slow pokes.
How bout those dorks too scared to drive without headlights or in the daytime!
Old Mar 17, 2009 | 03:44 AM
HCR13's Avatar
Car: 1987 Trans Am
Engine: 355ci L98 soon to be turbo'd
Axle/Gears: 2.73 posi
I honestly wouldn't go with that kit. I had the BOA keyless entry remote start kit which was ok. I then bought a kit off ebay that was a bit better. It had light confirmation and horn confirmation aswell. I was much happier. As far as relays, it will depend what kit you get. I believe our door locks are positively charged IIRC...meaning you need to add (+) to lock/unlock. If a kit is only (-) you need a relay to convert the - to + . I also like the remote start for the cold winter. It also has a trunk open (if you have an electic trunk button)...
Old Mar 17, 2009 | 07:22 AM
loopingz's Avatar
OK thanks for the feedback.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
BlackphantomZ28
Aug 31, 2015 11:19 AM
BlackphantomZ28
Aug 22, 2015 01:00 PM
