Ignition problem
Old Apr 27, 2009 | 03:49 PM
worxsinprogress's Avatar
Ignition problem
My 84 ta wont stay running. It will start occasionally and then the tach bounces and it dies. Then it wont start for a couple days and then it will fire up the first time, run for about five minutes , and thendie.Ive replaced the distributor, coil, and hei module but nothing works. Any ideas would be appreciated.
Old Apr 27, 2009 | 06:34 PM
macertheracer's Avatar
Car: '91 RS CP now is the son's driver
Engine: CP =3.1, will get V-8 maybe someday
Transmission: stock
Axle/Gears: 3.42 posi W/ disks
Re: Ignition problem
are you getting spark to the pluggs? if not try replacing the reluctor ring. 8 pointed ring in the bottom of the distributor, you have to take the distributor apart. had that problem on a '69 Camaro years ago. change the condensor in the dist' it is on the wiring harness inside the dist' awating your answer
Infested
May 22, 2018 11:56 PM
mddaniel
Sep 8, 2015 05:16 PM
Bryan F
Aug 27, 2015 07:28 AM
Bryan F
Aug 18, 2015 02:28 PM
