Voltage Drop
Old Sep 13, 2009 | 04:50 PM
rodgersje's Avatar
Voltage Drop
I'm having problems with voltage drop in my 89 camaro 305TPI. When sitting at a stop light it will drop, you will hear RPM drop and than it will come back up. I can also hear it load down when I turn on the rear defrost. Also acts up sometimes with my foot on the brake at a stop light. I have a new alternator but that didnt help my problem at all. Anyone with ideas would be greatly appreciated. Also I'm not sure if its relevent to this problem or not but I'm getting ignition noise through my radio. It gets louder as RPM increases.
James
Old Sep 16, 2009 | 01:16 PM
rodgersje's Avatar
Re: Voltage Drop
Anyone?
Old Sep 17, 2009 | 02:47 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Voltage Drop? Pick It Up!
That isn’t a problem if the voltage goes up to normal once you hit the loud pedal.
Ignition noise:
Make sure you are using resistor plugs and wires.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Fog lights are not driving lights. They look dorky. Turn em off slow pokes.
How bout those dorks too scared to drive without headlights on in the daytime!
Old Sep 18, 2009 | 03:05 PM
rodgersje's Avatar
Re: Voltage Drop? Pick It Up!
I havent changed any of the wires or anything before this noise started in the radio
Old Sep 22, 2009 | 01:00 PM
NINÅ's Avatar
Transmission: 765R4
Check for bad/disconnected ground wires.
Happy Racing!
Old Sep 24, 2009 | 01:22 PM
rodgersje's Avatar
Found the problem, All stemmed from a loose positive cable on the battery
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
