Unique tach issue.
Old Nov 9, 2009 | 08:27 PM
rtchaney's Avatar
Car: 89 RS
Transmission: Auto w/ evil shift kit; not my doin
Axle/Gears: It has a locker; not my doing
Unique tach issue.
This is interesting, the tach in my Camaro is reading twice what it should. I know that if it were aftermarket, that wouldn't be a hard fix; the car is bone stock though. Any ideas? I haven't pulled the cluster yet and the white wire is connected firmly to the coil.
- R
Old Nov 9, 2009 | 08:43 PM
madbomber824's Avatar
Car: 1986 Camaro
Engine: 350-Carb
Transmission: 700-R4
Re: Unique tach issue.
just from personal expierence i did a v6-v8 swap but when completed i hooked up my origional tach and realized that it was reading way too high rpm than it actually was. I did some research and the v6 and v8 tachs are programmed different. Was it always reading high? Ever a engine swap?
Old Nov 9, 2009 | 09:13 PM
rtchaney's Avatar
Car: 89 RS
hmmmm... It's a new to me car but the vin states that its a TBI 305. Although, now that I think about it, the title is exempt on mileage. Maybe a cluster swap? If so, how can I fix this on the cheap?
Old Nov 9, 2009 | 09:32 PM
Car: 1986 Camaro
Engine: 350-Carb
umm u can find a person thats good at programming computers and such can probably do it fairly cheap. maybe check all ur connections and everything first.
Old Nov 10, 2009 | 04:20 PM
joshhsi's Avatar
Car: 1991 Camaro Z28
Engine: 305 TBI
Transmission: 700r4 w/B&M Shift Kit
I had the same problem with a "doubled" tach. I found a used rs gauge cluster online for $20.00, pulled the gauge and the little circuit board and it now works fine.
$750 L98
Feb 1, 2025 02:25 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
Eric-86sc
Sep 28, 2015 11:37 AM
Lmancha96
Sep 25, 2015 08:11 PM
TrevinE
Sep 14, 2015 03:20 PM
