High Beams?!
Old Nov 23, 2009 | 08:00 PM
LambOfGod's Avatar
High Beams?!
So I've been looking for the damn high beam switch but cant seem to find it anywhere, my regular lights work but I can't figure out how to turn on my high beams, I have a 1986 z28, can someone please tell me how to switch 'em on immediately? Thanks.
Old Nov 23, 2009 | 08:05 PM
Blind Driver's Avatar
Car: 1986 Trans Am
Engine: 5.0
Axle/Gears: beats me
Re: High Beams?!
Pull back on the turn signal switch
Old Nov 23, 2009 | 08:08 PM
LambOfGod's Avatar
Re: High Beams?!
Lol! Wow... Thanks man.
Old Nov 23, 2009 | 09:56 PM
Al Hasse's Avatar
Car: 1992 RS / 1989 RS
Engine: 3.1L MFI / Vortec 383 TBI
Transmission: T5 / LS-T56
Axle/Gears: 3.42 open / 3.73 Eaton posi
Re: High Beams?!
The actual switch is on top of the steering column, down near the floorboard. It may be as simple as the actuating rod being misaligned and all you have to do is slip it back into the switch.
Do you get a click when you pull back on the blinker stem? Do the low beams tun off?
Old Nov 23, 2009 | 10:19 PM
zbackster44's Avatar
Car: 91' RS Camaro T-Tops
Engine: 305 TBI
Axle/Gears: Stock
Re: High Beams?!
I have a 91' camaro. When i went to replace my ignition switch it was located right next to the switch on the left side. what your going to have to do is drop your steering will down and check the High beam relay. Just to let you know the bolts that hold that in place also hold the Ignition switch in place so be carful.
sp8ty
South East Region
Sep 24, 2018 03:55 PM
sp8ty
Exterior Parts Wanted
Oct 23, 2015 08:35 AM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
