tach not working
Car: 69 Barracuda Mod Top
Engine: 360
Transmission: 727
tach not working
I have switched to a vaccum advance distributor and now the tach isnt working. The single wire is hooked to the coil/distrib. Do the tachs run through the ecu?
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: tach not working
The cc dist had a wiring harness connected to it - there should be a white wire and a pink wire in that harness (I think these are the colors) - these need connected to the new distributor. Search HEI distributor or check the tech article on carb swap.
eightsixseven
Dec 16, 2024 01:50 PM
