no dash lights?!?!?!?
Old Feb 8, 2010 | 09:26 PM
hijyackle's Avatar
86 firebird 2.8 auto...when i turn on the headlights my gauges don't light up, my clock goes dark (factory tape deck), my right turn signal indicator is illuminated (not flashing) and very dim...i took the dimmer switch apart and it looks fine...I've had this problem before and replacing the melted dimmer switch fixed it...all fuses good...bad ground? blown cluster bulb? all help appreciated...thanks
Old Feb 9, 2010 | 11:26 AM
ACCLR8N's Avatar
Car: 87 Evoluzione, 84 TransAm, 05 GTO
Engine: LT1, L98, LS2
Transmission: (2) T56 & (1) 700R4
Axle/Gears: Moser 12-bolt w/3.73 & Stock
Re: no dash lights?!?!?!?
Dim bulb that is not supposed to be on is usually a bad ground.
Old Feb 9, 2010 | 02:52 PM
hijyackle's Avatar
where is the ground for the dash lights?
Old Feb 9, 2010 | 03:39 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Found Ground
The grounds are located on the convenience center bracket.
The convenience center is located behind the knee bolster.
The convenience center contains a flasher (just to help you identify it).
You might have a cracked circuit board trace (difficult to see).
You might have a loose or dirty contact on the connector(s) for that circuit.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
When you see fog or “running” lights on in good weather beware. Low performance driver ahead.
How bout those nitwits too scared to drive without headlights in the daytime and the nitwits that need headlights for a little rain
Old Feb 10, 2010 | 01:54 AM
RScamaropos's Avatar
Car: 1992 RS Camaro 25th Aniversary
Engine: 5.0 TBI V8
Transmission: 5 speed manual
Re: Found Ground
I have a question. This is sorta related. So my headlights work but none of my dash lights or the fog lights work. Any ideas what happened? I assume this happened after I was doing spins in the rain . I checked all fuses I found one blown (didnt fix the problem so i dont know what it did) none others are bad. Could it be the dimmer switch?
Old Feb 10, 2010 | 09:29 AM
hijyackle's Avatar
Re: Found Ground
it was my dimmer switch...i bypassed it and everything is working fine
Pilotrick50
Sep 2, 2015 12:48 PM
stalkier
Aug 13, 2015 12:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
apie2546
Aug 8, 2015 07:12 AM
