need to know what these go to?
ok i was goin over the 89 rs from the wife, and i found a few cut wires, ive fixed two conecters so far and i have a question....on the drivers side of the engine bay, theres a wire cluster that the powersteering system has a conecter from and the horn wireing, but it also has two wires that i can not find a conecter for there for i dont know were they go....they are solid blue, and solid red, they apear to be factory because they are inside of the factory wiring harness at that area of the car....i need to know what they go to because like i said erlyer they arent just laying there they have been cut or torn......im guessin a lil bit of both for some reason...i dont have pics and i dont know how to post them either .....thats why i gave as good of a discription as i can.....any help would be greatly apreciated thanks....
Car: 1987 Camaro Iroc Z28
Engine: 350 S/B
Transmission: 700 R4
Axle/Gears: 2.43 Gear Ratio
Re: need to know what these go to?
Does your windshield washer fluid reservoir have an electrical connection going to it? There is a solid red and solid blue wire running to the plug for that. I traced this out on my '88. If you need I can post pics.
by all means please do post pics and if you can trace them back to were they go into the harness post a pic of that too so i can tell if its them or not please....thanks...and i dont know much about the cars, so i dont even know were the res. is so i couldnt tell you...lol....i was able to fix the wires going to the air intake at the radiator and the wires going to the aire intake toob.....(yes im new to gm cars)...lol
