Changed distributor cap, now the car grounds out
Old May 29, 2010 | 09:02 AM
tchernobog's Avatar
Car: 1991 Z/28 1LE
Over the past few days, I have had nothing but problems with my car. It hasn't started since tuesday. First I had the starter die. Then the starter enable relay. Then the ignition coil. Then the distributor cap.
So I replaced all of that, and now every time I try to start the car, I lose all electrical stuff. If I wiggle the distributor cap around for a few minutes, I can get the interior lights to turn on, and I get electricity back to everything. Problem is, as soon as it turns not even half a crank (I would assume when the rotor turns) the car loses everything.
I have absolutely no idea why. The cap is on there tight, I can't find any bad ground to the cap.
At this point, I'm at the end of my rope. If it's not an easy fix, I'm just going to get rid of the car. I have spent so much time and money trying to fix it, I'm tired of it, it's a waste.
Old May 29, 2010 | 11:02 AM
tchernobog's Avatar
Car: 1991 Z/28 1LE
Re: Changed distributor cap, now the car grounds out
Well, I've ruled out the distributor or cap.
Old May 29, 2010 | 02:13 PM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
sounds like you got a dead short somewhere near the back of the motor..or a loose power or ground wire.
Usually when a car looses full power of everything ..its easy to find by wiggling wires.start from the battery and work your way around...when you hear or see any small electrical sparks..your very close.
also check that the power wire going down to the starter isnt cut or touching metal.Good luck
Old May 29, 2010 | 03:47 PM
tchernobog's Avatar
Car: 1991 Z/28 1LE
Wow. So my hot wire coming from my battery was a tiny bit loose. It had enough of a connection that it tested OK, but when the engine moved during cranking, it lost connection.
But, after almost 5 days, a lot of hours, and a lot of money on parts, my car is finally back on the road.
Old May 31, 2010 | 02:04 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
It always something simple that frustrates the hell out of you. Good to hear its back to normal.
Old Jun 1, 2010 | 11:49 AM
tchernobog's Avatar
Car: 1991 Z/28 1LE
9 times out of 10 it is haha. Getting to the connection, however, wasn't easy. It wasn't the connection at the battery, it was the other end, which, as I'm sure you know, on an entirely stock engine, is tucked away in a place no normal hands can fit.
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
kah992
Aug 19, 2015 02:55 PM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
