Headlights Dont Work??
Car: 1989 Camaro RS
Engine: V6
Transmission: AT
Hey my headlights dont work and I cant figure out why. All the lights work I put them in my other camaro to make sure. I have replaced the headlight switch but havent really known what else to look for. Anyone with some experience working with electrical stuff wanna help me out cause I cant drive at night.. 1989 Camaro
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: Headlights Dont Work??
Take a scrap piece of wire and hook it to the green wire on driver side headlight, then touch it to the + on the battery.
If they pop upand come on, its wiring elsewhere.
had to jimmy rig mine like that once before to get home.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
No Lights, Outa Site !
He knows the lamps are good, he tested them.
Therefore Reyman, use voltmeter or test light (the type for testing for voltage, not a continuity tester) to probe the 12 AWG red wire going to the headlight switch.
Is there power there?
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Happy Racing!
Car: 1989 Camaro RS
Engine: V6
Transmission: AT
Re: No Lights, Outa Site !
Hey I checked that red wire you told me to and there wasnt any power going through that... Anything else?? Thanks
Transmission: 765R4
Yes. Because there is no power there, the fusible probably blew.
The fusible link is located near the starter solenoid.
Happy Racing!
8 Wheels Corner Better Than 4, If You’re On The Outside You Have Fair Warning
Happy Racing!
Car: 1989 Camaro RS
Engine: V6
Transmission: AT
I found the fusible link and there is some exposure and part of it is all taped do I have to take the whole wire out??
Transmission: 765R4
The Missing Link ‼‼‼‼ A Scary Movie
First check both sides of the fusible link with your meter or test light.
One side should have power, and the other side shouldn’t if the link is bad.
If that’s the findings replace the link.
Fusible links are available at auto parts stores.
Happy Racing!
“I Didn’t Jump The Start, The Flagman Was Late”
Happy Racing!
Ghettobird52
Jul 5, 2024 11:18 PM
The_Phoenix
Feb 4, 2016 07:10 AM
1990, 68firebird, bad, body, camaro, components, dont, electrical, fusible, gen, head, headlights, lights, link, sides, work
