Removing check engine bulb advice please
Car: 1987 Trans Am
Engine: Chevy 350 .040 over
Anyone have advice on removing my check engine bulb? I have never taken apart anything in the dash before and would prefer not to break things. Can I simply take out a few screws and reach up and snag it out?
Thank you!
Thank you!
Re: Removing check engine bulb advice please
Im assuming this is for a carb swap
1) Remove the cluster and pull the bulb
2) Unplug the old ECM
3) Cut the C207 pin C wire (brn/wht)
