Hatch Lid Motor Question
Car: 1989 Camaro RS
Engine: Modified 350 TPI
Transmission: Modified 700 R4
Axle/Gears: Posi 3.42
Is there a way to manually engage the motor? My lid motor is stuck in the up position. Hatch loop switch is new, relay is new, no fuses blown, power and grounds are good.
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Stuck Up With An Attitude
The internal reversal switch might be bad.
If it is there is no external connection you can make to run the motor.
Happy Racing!
Slamming The Wall Is Not The Neatest Way To Remove An Engine
Happy Racing!
Car: 1989 Camaro RS
Re: Stuck Up With An Attitude
Got it fixed. Not sure what happened though. I took off the motor and touched prongs on the motor to a hot and ground and it worked. I put everything back together and it works fine now......wierd.
1992 Trans Am
May 10, 2023 07:19 PM
