radio and dash lights don't work
Old Sep 24, 2010 | 06:24 AM
primaryfitness's Avatar
Car: 1989 Formula 350
Engine: 5.7l
Transmission: auto
Axle/Gears: BW 9 bolt w/3.27 gears
I have a 1989 firebird formula I just bought that has a strange problem. When i turn the headlights on the instument cluster goes dark and the radio loses power. Everything else works as it should and as soon as I shut the lights off the radio gets power back. Any ideas as to what could cause this?
Old Sep 27, 2010 | 09:55 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Light Fright
Using a voltmeter or test light (the type for testing for voltage, not a continuity tester) probe the INST LPS fuse, while the switch is in the HEADLIGHTS ON position, and you are rotating the dimmer control back & forth.
Is there is power there?▬Steady or it varies?
Then do the same test with the switch in the ALL LIGHTS OFF position, and you are rotating the dimmer control back & forth.
Happy Racing!
I Didn’t Wreck, The Track Moved
Old Sep 27, 2010 | 10:06 AM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: Light Fright
Does this have an aftermarket radio? A hack job would be where to start if an aftermarket radio was installed. Just one more area to look into.
Old Sep 29, 2010 | 02:47 PM
Engine: 5.7l
Transmission: auto
Re: Light Fright
I don't get any power either way
Old Sep 29, 2010 | 03:33 PM
NINÅ's Avatar
Transmission: 765R4
Light Fright
OK due to the fact there’s no power at the INST LPS fuse, but the instrument lamps illuminate when the headlight switch is OFF, makes it sound like there has been rewiring by the PO.
Let’s find out if the responsible part of the headlight switch is good.
Using your test light or meter, probe the
dark green wire at the headlight switch, when the headlight switch is in the HEADLIGHT ON position, and you are rotating the dimmer control back & forth.
If there is power there, you have a broken connection from that point, to the
INST LPS fuse.
If there is NOT power there, the headlight switch is defective and might have been bypassed by the PO.
Happy Racing!
I Hit The Water Barrels Because My Car Was Dirty
Old Sep 29, 2010 | 03:55 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: Light Fright
Another possibility is a failing fuse link at the starter. There are three fuse links at the starter. One protects the alternator charge circuit, one provides power to the ignition switch, the other provides power to the light switch. If these fuse links are damaged or if there is a poor connection at the starter, it could cause excessive volt drop when the head lamps are turned on.
Ghettobird52
Jul 5, 2024 11:18 PM
Vintageracer
Jan 10, 2020 05:33 PM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Omega
Aug 10, 2015 12:46 PM
apie2546
Aug 8, 2015 07:12 AM
