Same question, a little different
Old Dec 19, 2011 | 05:14 PM
F15david's Avatar
Car: 91 RS
Engine: 383 Stoker
Transmission: Monster Mortorsports built 700R4
Axle/Gears: 9 bolt 3.27
Ok so I just got a cheap 91 rs with a carbed 383 stroker. The previous owner hacked the wiring harness to bits. Its pretty bad. Now I have read many, many threads here but none really told me what I can get rid of and what I HAVE to keep. (for running not for legality) I have all alternator, starter, dizzy and ground wires separated. My real question is do I need the power steering pump switch or anything else wired up from the original harness. I am rewiring the fuel pump relay and the fan. Any help would be great. Thanks
Old Dec 20, 2011 | 10:48 AM
85irocinjected's Avatar
Car: 1991 RS
Re: Same question, a little different
Since your not running a computer your don't need that switch. And since it is carbed you can remove EVERYTHING thats not needed specifically for the engine/trans to operate properly.
Old Dec 20, 2011 | 05:22 PM
F15david's Avatar
Car: 91 RS
Engine: 383 Stoker
Thats what I thought but I just wanted to be sure. Thanks for the info
Old Dec 21, 2011 | 02:29 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
remove the ENTIRE passenger side wiring harness along with the ecm. the driver side harness and passenger side AC harness go untouched. you can tap into a switched 12v wire on the driver side harness for the dizzy.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
