What is this?
Old Feb 27, 2012 | 08:56 AM
1badeagle's Avatar
Car: 1984 Formula ws6
Engine: 370 LSX
Transmission: 4L80E with a brake and 4500 Stall
Axle/Gears: Moser 9" 4.30 gear
What is this?
I realize its not a fbody, but what is this little square with wires going into it? Its on a 87 el camino. I have been eliminating wires and all the emissions stuff since we just installed the new crate motor and I need to know if this is needed to make the car run or not.
Old Feb 27, 2012 | 10:04 AM
dellman83Z's Avatar
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
Re: What is this?
map sensor and you may need it depending if the motor needs it, maf or map computer.
Old Feb 27, 2012 | 04:53 PM
1badeagle's Avatar
Engine: 370 LSX
Re: What is this?
We are running a carb and the original hei distributor. Transmission is a th350 manual valve body with a brake. So I don't think we need a map?
Old Feb 27, 2012 | 06:42 PM
utilityguy2's Avatar
Re: What is this?
then get rid of it.
