no headlights!?
Old Mar 30, 2012 | 03:17 PM
SR71BLKBRD's Avatar
Car: 92 Firebird, 91 GTA
Engine: 305 TBI, 350 TPI, * LS1 (Building)
no headlights!?
Hey guys on my way in to work this morning my headlights just cut off? They were such on the high beams. I tried to disengage the high but to no success...i'm wondering if its Tue lever cause my cruise control is funny...I turn it on and it works for about 5-10 minutes then it just cuts and slows down? I'm thinking its the lever...any info is appreciated! Thanks Trae
Old Apr 2, 2012 | 04:25 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Need Light 4 Night
Well first the lights so you can drive at night.
It sounds like the dimmer switch is not engaging properly due to misalignment.
If you have tilt steering make sure that is operating with no play.
Then you can adjust the dimmer by loosening the hardware at the bottom of the column, then slide it into position, tighten it then test with stalk, then readjust as required.
Happy Racing!
Rule Number 1 Is To Know Which Rules You Can Break
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
