Messed up Fuse Box
Old Jun 1, 2012 | 10:02 AM
jhuebner's Avatar
Car: 1987 Trans Am
Transmission: STOCK
Messed up Fuse Box
I recently was fixing my radio and gauges. I have a 87 trans am with digital gauges. and i was messing with the fuses and now when i start my car and it idles it shakes really hard and the accleration is slow now and it doesnt get out of first gear till over 4,500 rpms. Anyone know if a fuse could cause this?
Old Jun 1, 2012 | 10:07 AM
heat seeker's Avatar
Car: 89 Formula
Engine: 383 SBC/HSR
Re: Messed up Fuse Box
Did you check all the fuses? Are any of them blown? Also, is the voltage low on your gauge?
Old Jun 1, 2012 | 10:12 AM
jhuebner's Avatar
Car: 1987 Trans Am
Transmission: STOCK
do you know what fuses would cause this? I have a diagram here of the fuse box.
Old Jun 1, 2012 | 10:36 AM
Car: 89 Formula
Engine: 383 SBC/HSR
Have you checked your fuses?
Old Jun 1, 2012 | 10:43 AM
jhuebner's Avatar
Car: 1987 Trans Am
Transmission: STOCK
i just ordered all new fuses for my car from advance auto parts and going to pick them up soon. Hopefully that does the trick.
Old Jun 1, 2012 | 10:49 AM
Car: 89 Formula
Engine: 383 SBC/HSR
I don't understand why you went that route. You may have only needed one fuse, or you might not need any, it could be a wire crossed.
By looking at the fuses with a flashlight you can easily spot if one is blown.
Old Jun 8, 2012 | 09:44 PM
chrisvanguitar5's Avatar
Car: 89 Trans Am GTA
Engine: 5.7 L98
Transmission: 700 r4
Had the same problem man if it is still their than what u want to do is take out each injector at a time if the car changes the injectors are fine if not then either the injectors are bad or they arent getting power if three on a side do it its probably not getting power replace your injector fuses even if they look okay and it shoupd run better but i woupd let it sit with the megative terminal disconnected over night to reset the comp so it doesnt run improperly
83 Crossfire TA
Sep 18, 2015 12:01 PM
Tweeks25
Sep 17, 2015 08:04 AM
gta892000
Sep 16, 2015 12:37 AM
timonator
Sep 10, 2015 07:55 PM
64goatman
Sep 9, 2015 01:09 PM
