Blinker issues
Old Jul 14, 2012 | 09:22 PM
Ralikandiel's Avatar
Blinker issues
I have an 88 Camaro I recently purchased. Runs great, however none of the blinkers on the right side work. The turn signal light inside the car is always on, not blinking, but just steady, and the left side has no issues.
Anyone have an idea of what the problem could be? Cause i'm stumped.
Old Jul 16, 2012 | 04:31 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
I Think, Therefore I Blink
First check all right side bulbs and side markers to make sure they are the correct type, and installed correctly.
A common mistake is people installing 2 filament bulbs 180° rotated.
If they are all OK use a voltmeter or test light
(the type for testing for voltage, not a continuity tester) with the key in the RUN position, turn stalk in the right signal position, probe the dark blue wire out of the column.
Is there power there?
Happy Racing!
I’ll Bump You Once To Move You Over, Next Time I’ll Spin You
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
nova983
European Region
Nov 2, 2015 12:15 PM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
