2 step and line lock wiring
Old Jul 16, 2012 | 08:02 PM
mikebondi's Avatar
Car: 91 Camaro RS
Engine: 6.0 lq9 ls bored to 408
Transmission: T56 6 speed
Axle/Gears: strange s60 4.10 with a spool
ok i didnt know if this should be in electronics or drag racing but here it goes.
i have a line lock roll control and a msd ls 2 step in my car. right now they are both wired to a switch on my shifter ****.
what i want to do is wire the 2 step and the line lock both to my clutch switch. that part seems pretty easy. the hard part for me at this point is i want to be able to activate the line lock off of the button on the shifter as well for burnouts.
i was thinking a toggle switch that would direct the line lock from the switch on the shifter to the clutch. this way i could flip the switch after the burnout and have the line lock and 2 step both active with the clutch to the floor to keep car from rolling at line. then launch the car and have the two step and the line lock both go off at the same time.
seems like it would be easier than having to worry about letting the clutch out and letting off the line lock button both at the same time.
thanks guys
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
