Negative Battery Lead Location ?
Old Jan 18, 2013 | 11:21 AM
rhyspat's Avatar
Car: 87 firebird
Engine: 2.8 MFI
Hi All,
I am in the process of putting my engine back in my Firebird. It's nearly all done, however.........I cannot remember where the battery negative lead bolts to ?.
I have it marked as on the engine under the PS pump - is that right - shall I just hook it to one of the PS bracket bolts ?
BTW, Battery is located on the drivers side.
Thanks for someone to clarify so I dont attach it somewhere wierd.
Rhys.
Old Jan 18, 2013 | 11:55 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: Negative Battery Lead Location ?
There is a place for a bolt on the PS pump side of the crank pulley (just above the center line of the pulley). Should have a bolt in it about a 1/2" long with a 15mm head. Make sure that you clean the block around the hole, the cable eye, and the bolt up nice with a wire wheel or brush before you put the cable onto the block.
Old Feb 26, 2013 | 12:52 AM
DiabloWS6's Avatar
Car: '86 TRANS-AM WS6
Engine: 1989 355 TPI L98
Transmission: TH700R-4
Axle/Gears: BorgWarner 9 bolt/ 3.27
im looking for the same thing i actually just used a side of mr header bolt and put it for the time being if possible could you take some pics of the location so i can get a visual
Old Feb 26, 2013 | 03:04 PM
gt4373's Avatar
Transmission: 5-Speed Manual
This Is The Factory Location For A 305 Engine Yours May Be Different
Old Feb 26, 2013 | 04:13 PM
DiabloWS6's Avatar
Yeah it's different but i have an idea of were it would be at
64goatman
Sep 9, 2015 01:09 PM
TBRays98
Sep 6, 2015 05:05 PM
middian
Sep 5, 2015 01:42 AM
Formula_88AE
Sep 3, 2015 01:47 PM
tonys91rs
Sep 2, 2015 07:07 PM
