Losing my computer
Old Feb 10, 2013 | 09:04 PM
audioc's Avatar
Car: 1986 trans am
Transmission: 5 speed
Losing my computer
I'm replacing my old 305 in my 1985 trans am. I'll be putting in a new 350 long block. I'm taking out all the smog stuff and would like to ditch the computer. Any idea's. Will my stock rodchester carb work? If i get rid of the computer does this affect the gauges ( oil ,water,batt and their warning lights). LOve this forum and all your help!!
Old Feb 10, 2013 | 09:10 PM
LostX's Avatar
Car: 88 Trans Am
Axle/Gears: Posi
Re: Losing my computer
i ditched the computer and removed every wire passing through the hole in the back passenger side of the engine compartment by the ac stuff.
Just leave the yellow 4-out buffer thing in place and relocate the ground for it, black with white stripe wire. And reconnect the brown wire that does something with the alternator.
Old Feb 11, 2013 | 01:27 AM
fljerry's Avatar
Car: 1984 Camaro
Engine: 5.0 Liter (305 ci)
Transmission: 700R4 Automatic
Do you know what the computer controlled, just the smog equipment? I'm thinking of removing mine also but will be using my 1984 Z28 as an everyday commuter in Florida so I would like the AC, radio, power windows, etc. to work.
Old Feb 11, 2013 | 04:48 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Computer only controls engine related functions
Old Feb 11, 2013 | 08:43 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Not well.
Old Feb 11, 2013 | 05:09 PM
audioc's Avatar
Car: 1986 trans am
Thanks, Didn't think so.. First time i've worked on a car in 35 years. Kinda fun. Got the motor out myself with the tranny still in. Hope it goes in easy!!! Any tips?
Old Feb 11, 2013 | 05:15 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Use studs instead of bolts to attach the bellhousing to the engine. Makes lining things up a lot easier.
Old Feb 11, 2013 | 05:17 PM
audioc's Avatar
Car: 1986 trans am
Meaning putting the studs on the block?
Old Feb 11, 2013 | 05:29 PM
Sidethumper's Avatar
Car: 87 Pontiac Trans Am
Engine: Lapouttre Racing 350
Transmission: Rebuilt 700r4 Mild shift kit
Axle/Gears: 10 bolt 3.23 posi w/disc brakes
I too am doing the same thing to my 87. I have to clean up under the dash and figure out what wires to get rid of on the harness to the engine bay. Putting in an 350 as well.
Old Feb 11, 2013 | 05:42 PM
audioc's Avatar
Car: 1986 trans am
Yours looks like you had it totally part . Mine was almost perfect except for a dirty engine compartment and a small leak at the water neck. Now i took out the motor just to detail it. It had 66,000 on it and ran perfect. don't want to put back in a used motor and well you know where it goes from there. I think it's a decease!!!!
Old Feb 12, 2013 | 03:23 AM
Oh yeah. I tore the entire car down. And putting almost all new parts in. Its been interesting to say the least
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
dusterbd
Sep 29, 2015 08:40 AM
Damon
Sep 26, 2015 04:29 PM
Stryker412
Sep 20, 2015 06:59 PM
