Flickering lights
Old May 14, 2013 | 10:02 PM
oSnooZe's Avatar
Car: 1984 Chevy Camaro
Flickering lights
My high beams will not work. The low do work without a problem. When i turn them on they flash in some sort of pattern. I just replaced the headlight switch. My high beam indicator in the dash does not work neither do the turn signals. they did previously work until a few weeks ago. Please ThirdGen Community, Fix My Ride.
Old May 18, 2013 | 01:29 AM
Stallion's Avatar
Re: Flickering lights
Not sure if anyone worked on it before, but for the turn signals could possibly be a bad flasher located under the panel. There should be two, one for hazard and one for signals.
For the high beam, there is a mechanism and a small bar along the left side of the interior of the steering column. This activates the high beam. Inform me if you find anything. Thanks.
Old May 24, 2013 | 11:10 PM
Eric0840's Avatar
Car: 1988 Iroc Z
Hey u mean there is a mechanism for the high beams?? cuz I was wonder if that was true or not or I needed to replace the whole wiper stick to make the high beams work
TrevinE
Sep 14, 2015 03:20 PM
florida_gators
Exterior Parts Wanted
Sep 7, 2015 07:19 PM
flash2042
Interior Parts Wanted
Sep 7, 2015 07:15 PM
luvofjah
Sep 3, 2015 07:08 PM
