Engine bay wiring question
Old Jun 25, 2013 | 07:48 PM
primaryfitness's Avatar
Car: 1989 Formula 350
Engine: 5.7l
Transmission: auto
Axle/Gears: BW 9 bolt w/3.27 gears
So I just picked up a 1985 TA with no motor or tranny. The previous owner cut all the wiring under the hood to pull the motor out. I figured out the wiring harness on the left side by the brake booster but my question is about the wiring on the passenger side that goes in the fender. Will I need that wiring if I run an older carb. motor? That harness goes to the ecm under the dash. There are a few other seperate plugs in that harness that go under the dash,what are they for? Any help would be appreciated.
Old Jun 30, 2013 | 01:06 AM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: Engine bay wiring question
I think you will need a carb harness then that attaches where the brake booster is. The passenger side is for a TPI harness and most of the motor connections where on there
Reddeath210
Oct 6, 2015 08:20 AM
AkDrifted
Aug 17, 2015 07:45 PM
redmaroz
Aug 16, 2015 11:40 PM
jahblah
Aug 12, 2015 05:54 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
