Brake Lights wont come on.
Old Jul 11, 2013 | 09:20 PM
penguinpanda0's Avatar
Car: 1987 IROC-Z Camaro
Engine: 305 LB9
This shouldnt be this hard, I've got a new brake light switch, all new bulbs, the ground looks good, and I cant see any faults in the wiring. Any theories? The Back Up Lights and the Turn Signal Lights work, just not the brake lights...
Old Jul 13, 2013 | 05:31 PM
6SIX6's Avatar
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: Brake Lights wont come on.
Did they work before you replaced the brake light switch? Do you have another switch to swap and see if it has the same issue?
Old Jul 15, 2013 | 05:03 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Braking Bad Habit
Do the Hazard Lights work?
If no, use a voltmeter or test light
(the type for testing for voltage, not a continuity tester) probe both sides (one side at a time) of the STOP HAZ fuse.
Is there power on both sides?
Happy Racing!
I Never Fight In The Pits . . . . . . . . . My Pit Crew Does That For Me
Old Aug 9, 2013 | 07:42 PM
Engine: 305 LB9
Re: Braking Bad Habit
My Hazards work... I dont understand, everything points to the brake lights working, except they dont. The answers are never clear with these cars lol
Old Aug 10, 2013 | 03:11 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Just basic Auto electrics.
Better question would be do you have power into and out of the brake switch?
If not , back track the circuit to find out why
Old Jan 14, 2014 | 11:11 PM
thatoneguy5x's Avatar
Car: camaro
Engine: 3.1
Transmission: auto
i know its been a couple months but did you ever happen to find the cause? I have the same exact problem. new brake switch and its not working. all the fuses look to be in working order but none of the wires goin to switch seem to have power. all my wires are wrapped up so I don't wanna tear into all of it just yet if its something simpler.
Old Jan 15, 2014 | 01:33 AM
Car: camaro
Engine: 3.1
Transmission: auto
nvm played with it for a long time and figured it out. thanks anyway. for any1 else that has this problem. make sure the contacts inside the brake switch are making good contact! I had to bend it a bit so it would work. my wires were loose as well. tightened everything up and reconnected it everything works now.
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
pigpete
Aug 15, 2015 07:56 AM
stalkier
Aug 13, 2015 12:59 PM
Omega
Aug 10, 2015 12:46 PM
