87 Trans Am GTA Taillight Wire Diagram Question
Old Aug 28, 2013 | 08:27 PM
BlackTopKing's Avatar
Car: 1987 Trans Am GTA
Axle/Gears: Posi 3:42
Kinda stupid, but I did search and what I found prompted the question.
Which is, diagram shows LT Blue wiring, but mine are purple....
So
A: use to be blue and 20+yr aging = purple...lol
Or
B: GTA taillights are different from Firebird/Trans Am....
I don't know
But the question, why do I have purple wires and does anyone actually have a diagram (not Haynes) for 87 GTA.
I've started going threw the car and I am finding, too many wiring pro mods (joke)
So I figure I ask
What's the purple wire! Lol
Old Aug 29, 2013 | 08:50 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: 87 Trans Am GTA Taillight Wire Diagram Question
You might not be looking at the "exact" diagram for your car.
Does your GTA have a Digital Dash in it.......
My 88 GTA (Digital Dash) has Purple wires @ the tail light harness. The purple wire appears to feed power to the LH rear lights. The wires feeding the RH rear lights should be Brown/White. ( 88 Shop manual diagram shows them for DD GTA )
They connect to the Light Monitoring Module.
P.S. Nice work on that WideBody !!
Old Aug 29, 2013 | 09:23 AM
Y
Dude, your awesome....
Yes its digital and I didn't even think that would effect it, but I guess it would (I know body harness different in some ways then non digital, but not sure how)
My question then would go a little further.
I have yellow and purple on LH,
Any ideal on the yellow, cause my first thought is that that would of been my hot in....but guess not if purple is.
Also, thank you for the compliment on the widebody, its slowly getting there. Should have a nice update after the weekend, so def check back in.
Thanks again
Old Aug 29, 2013 | 10:12 AM
John in RI's Avatar
No Problem !
slowly getting ther
Isn't that always the way it goes. Dude; If was easy,.... everyone would be doing it ! I'll be checking on updates from time to time.
Looks like for the Digital Dash Trans AM / GTA the LH Yellow and the RH Dark Green are the turn signal wires.
** On Firebird with Digital Dash,..... LIGHT BLUE wires feeds all the Brake lights in the rear ! ( Maybe that's why your diagram was showing that color ! )
1992 Trans Am
May 10, 2023 07:19 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
Exxon Limited
Aug 9, 2015 08:13 PM
