Help fix my rear defroster!
Car: 1988 IROC-Z/G92
Engine: 5.0
Axle/Gears: BW 3.45 Eaton Truetrac
Does anyone know how to fix specific lines of the rear hatch defroster? Its annoying when only like 4 lines work then it skips 3 broken ones and then another 2 work. Also, any way to keep it on longer? I hate having to press it over and over again while driving.
Thanks in advance!
Thanks in advance!
Car: 1989 IROC-Z / T-Top -1987 GTA
Engine: 305 (LO3) _350 (L98)
Transmission: 700R4 _ 700R4
Axle/Gears: 2.73 L.S. - ???
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Help fix my rear defroster!
It looks like the Frost Fighter has everything anyone would need.
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
I fixed mine with a conductive ink pen. Get your car in a dark garage, turn on defroster, and look for little sparks where the breaks are. Then dab on some ink.
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Yep, got all but a couple of lines working that way. I fixed the big breaks I could spot easily by eye first, then did this for the rest. Generally the breaks were down the sides of the hatch, where the individual lines join the main supply tracks.
AkDrifted
Aug 17, 2015 07:45 PM
