Need picture of trunk pull down wiring
Old Nov 27, 2013 | 04:14 PM
ventport's Avatar
Does anyone have a picture of their trunk wiring showing the mounted trunk pulldown and relay's with the colored wires plugged in? My 89 convert had a trunk full of mice and the wiring is a mess, shorted, burned, chewed. I need to see how the wires are routed and what colors go where. Thanks Brian
Old Nov 27, 2013 | 04:44 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Re: Need picture of trunk pull down wiring
While you wait for a photo, check out this page: http://www.austinthirdgen.org/index.php?pid=19
Old Nov 28, 2013 | 01:45 PM
305TBI's Avatar
Car: 1991 Firebird Formula
Engine: 305 TBI
Axle/Gears: 4.10
Brian,
This is pull down (hatch) and release wiring for my 1991 firebird formula 305TBI. Yours may be different, but they may be the same.
Attached Thumbnails Need picture of trunk pull down wiring-msd-testing0001.jpg   Need picture of trunk pull down wiring-msd-testing0002.jpg   Need picture of trunk pull down wiring-msd-testing.jpg
Old Nov 28, 2013 | 11:29 PM
MrPackstin's Avatar
Car: 1989 GTA
Engine: 5.7 w/Paxton
Check the blue wire connected to red/white wire to see if you have twelve volts. Ground is to body. If 12v and ground is good, then you probably have an electrical issue with the hatch motor assembly. Fuse is not in the fuse box but is near the box and taped to the wiring harness. Should be able to see it dangling. Wires are in loom which is inside the metal clips that bend easily and are glued to the chassis. Blk wire has a 7mm self-tapping screw holding it to the body-this is near the hatch assembly. Red/wht wire goes to the blue on the assembly and white to the other-can't remember color. PM m e if you need anything else.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
Infested
May 22, 2018 11:56 PM
bryan623
Aug 10, 2015 11:33 AM
mx127
Aug 10, 2015 08:13 AM
