Drivers door locks when ignition is switched to run.
Old Dec 5, 2013 | 04:03 PM
88 Convertible's Avatar
Car: 92' Firebird, 90' Vette
Engine: 305 TBI
Axle/Gears: 9-bolt bw 3.27
I have a 92' Firebird that has a pretty annoying feature. When you turn the key to run just the drivers door locks, It caught me off guard the day I bought the car and thought I had locked the keys it the car! luckily the passenger door was still unlocked .
Is this a security feature? and is it something that can be easily disabled?
Old Dec 6, 2013 | 08:05 AM
jwfirebird's Avatar
Car: 87 bird
Engine: enough to break stuff
Transmission: manual th400
Axle/Gears: 4.10
Re: Drivers door locks when ignition is switched to run.
not sure when they started doing the locking and unlocking but i want to say it was on the gear shift when they did. you may find a aftermarket security system installed if you look under the drivers dash
Old Dec 6, 2013 | 11:26 AM
Engine: 305 TBI
It might be an aftermarket system, but honestly I've never seen anything up under the dash that looks suspect. stickers on both the drivers and passenger door read "protected by black widow" but I never really paid any attention to it.
Old Dec 6, 2013 | 12:45 PM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
seems very likely then
Old Dec 9, 2013 | 05:08 PM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Left Door, Lock-No-Mor
It might be in a different location.
You can trace the
blue wire at the Lock Relay located behind the left shroud.
Physically trace and look for splices to lead you to the module.
Happy Racing!
Don’t Blame Me For Spinning You, My Car Simply Took The Air Off Your Spoiler
Old Dec 10, 2013 | 12:19 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
They like to put the alarm system in the kick panel on the drivers side.
A typical alarm system cannot just be ripped out. There is some rewiring to be done. I have seen them professionally removed and when they showed me a complete harness, what looked like two relays and the main module there must have been at least 20 feet of wire.
Old Dec 10, 2013 | 06:58 AM
jwfirebird's Avatar
Car: 87 bird
Axle/Gears: 4.10
depending on the features it could be wired into the trunk or hood harness or starter enable circuits too
BRoss99
Aug 10, 2025 05:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
chevyguy1999
Aug 16, 2015 08:49 PM
