erratic voltages at ecc on cts and tps
Old Feb 18, 2014 | 02:40 PM
bluegrassguitar's Avatar
Just changed the cts and tps because they were throwing codes. the are still throwing codes and I have the tps set to .6 just like its suppose to be. I did clear the codes several times too. when I check the voltage at the cts it is showing that it is measuring correctly i.e. it's going down to 1.2-1.4 with the car running and warmed up but when i do to measure at the ecc its going from 1.2-5v. I have checked the grounds and all are good. Can this be a problem with my computer?? It is a re-manned one but i am unsure how old it is. I also opened it up and there is no where that is discolored it looks new and I also tried the "hit it hard and see if the cars surges" test and there was no difference. Can anybody shed any light to the situation??
Old Feb 19, 2014 | 12:53 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: erratic voltages at ecc on cts and tps
Work through the fault diagnostics.
A code is for a fault SOMEWHERE in the system ; not just that the sensor itself is faulty.
http://www.chevythunder.com/cts_diagnostics.htm
http://www.chevythunder.com/cts_diagnostic_pg2.htm
http://www.chevythunder.com/tps_code_21.htm
http://www.chevythunder.com/tps_code_22.htm
mrbird
Oct 20, 2015 03:43 AM
HoosierinWA
Oct 7, 2015 10:15 AM
racereese
Oct 3, 2015 03:46 PM
thejimsterz28
Sep 30, 2015 08:52 PM
ironbmt
Sep 27, 2015 06:00 AM
