HELP Installing Painless TPI ECM Wire Harness
Old May 19, 2017 | 08:48 AM
marcial88's Avatar
Car: 1986 Camaro Z28
Engine: TPI 305 CI 5.0L V8 LB9
Transmission: AUTO 4 SPD 700 R4
Axle/Gears: 3.23 RATIO
Hey guys didn't know where to turn but here. Inherited this 86 Camaro from my father in law. The OE wire harness was a mess beyond repair, therefore I invested in a new TPI MAF cable harness from PAINLESS i havent connected the cables that run to the ECM or the steering column ill make sure to come here for help too. Problem is the following pictures hah a cables/connectors that I have no clue where to plug/connect or ground them to. I'm a rookie when it comes to grounding cables. Any help is appreciated and if possible pictures are more helpful than diagrams for. And the more detailed in the explanation the better. Any help?
Old May 19, 2017 | 08:53 AM
marcial88's Avatar
Re: HELP Installing Painless TPI ECM Wire Harness
Here are the pictures of the cables I need help with. I have one or 2 more but haven't taken the pictures of them.
Attached Thumbnails HELP Installing Painless TPI ECM Wire Harness-20170518_203959.jpg   HELP Installing Painless TPI ECM Wire Harness-20170518_203911.jpg   HELP Installing Painless TPI ECM Wire Harness-20170518_203626.jpg   HELP Installing Painless TPI ECM Wire Harness-20170518_203555.jpg   HELP Installing Painless TPI ECM Wire Harness-20170518_203455.jpg
Old May 19, 2017 | 07:03 PM
marcial88's Avatar
Bump
Old May 19, 2017 | 07:45 PM
88Greg's Avatar
Car: 88 Trans am
Axle/Gears: C4 IRS 3.42
Didn't that thing come with instructions ?
So that is a stand alone harness I think. You may have to do the mods to your C100 wiring that LT/LS swaps do. Does it have its own fuse block ?
But, Heres my guess :
-The VSS wire is intended to go to the VSS buffer (yellow box) that would have been in the original dash IF your car was originally an EFI car.
-The AC wire is probably meant to go to the AC compressor clutch to sense when its activated
-The Fuel pump wire looks thick, Probably meant to go directly to the fuel pump to power it. Does that harness have a FP relay in it ?
-The OIL wires are probably meant to go to the stock oil pressure switch (not gauge sender) That turns on when engine runs to provide a backup method to activate the fuel pump.
-The GROUND ring should go to a good clean spot on the engine (stock was a stud on the back of the cyl head)
Old May 20, 2017 | 12:41 AM
marcial88's Avatar
No fuse block. It did come with instruction but it only said to what to what to connect it to without going into details.
Old May 20, 2017 | 08:02 AM
Galaxie500XL's Avatar
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
Your best bet is to get a wiring harness diagram for your car, then you'll have a better idea what wire in the car goes to what wire on the harness.
Old May 20, 2017 | 08:18 AM
marcial88's Avatar
The car does have the fuel pump relay but the harness that connects to these relays is missing and the painless harness did not come with cables or connectors that run to them. Is there a separate harness that run to to the relays where the FP relay is located?
Attached Thumbnails HELP Installing Painless TPI ECM Wire Harness-20170516_155621.jpg   HELP Installing Painless TPI ECM Wire Harness-00v0v_49zrkeaacsy_600x450.jpg
Old May 20, 2017 | 08:41 AM
brian p's Avatar
Car: 86 IROC
Engine: Twin turbo L31 HSR
Transmission: 4L80E in progress
Axle/Gears: 9 bolt 4.11
You'll find that tan fuel pump wire you want to splice into running from the fuse panel down under the carpet on the driver side under the door sill. It runs into a connector under the back seat. The VSS wire is behind the dash (it's tough getting in there) but you can also find it easier at one of the two connectors (C207/C221) up above the heater box in the passenger footwell. There's a two or three prong sensor at the back of the intake. Thats where the oil pressure connectors go on. Check out Austinthirdgen. org for wiring diagrams and also check online for the instruction manual that Painless has for their complete TPI wiring harness, it has a better explanation. I installed the complete engine harness this winter, took some time and a bitt of guess work (because it's universal ) but everything you've got there does fit.
Old May 20, 2017 | 09:09 AM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
You REALLY should contact Painless. Get that diagram. The labels on the wires are not enough. For example, you need to know where in the fuel pump circuit that wire goes.
Old May 20, 2017 | 10:44 AM
88Greg's Avatar
Car: 88 Trans am
That's the stock MAF power relay, MAF burn off relay, Fuel pump replay, and ESC module you have there. Good, You will probably need all those. The relays all look like the 'older' square body style. That bracket mounts to the firewall by the brake booster.
The stock engine harness would have plugged into those and the C100 connector close by on the firewall. I am guessing you will have to create your own wiring from those relays to go to the painless harness.
Do you have any of the C100 plug and wiring ?
The wire that powers the in-tank fuel pump would have come out of one of those relays and then into the C100, and then back through the interior of the car. Does your car still have that wire intact ?
