Aftermarket Gauges How To?
Can Someone Tell Me Step By Step How To Wire A Fuel Gauge In My 89 RS 305 TBI
I Never Done Gauges Before So Im New I Would Believe The Same Concept Applies No Matter the Gauges Right? ...Help Please Thanks
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Re: Aftermarket Gauges How To?
Because you didn’t indicate the make and model of the gage this info is generic.
Connect the terminal labeled GND to ground.
Connect the terminal labeled I to a 12 volts present when ignition is on line.
Connect the terminal labeled S to the sender wire.
Connect the black wire from the gage to ground.
Connect the White wire from the gage to the dash illumination feed.
Happy Racing !
I Didn’t Hit The Wall, The Wall Hit Me
Happy Racing !
