need help with heater blower motor wiring - Third Generation F-Body Message Boards
Thread Tools Search this Thread
Old 11-13-2017, 05:35 PM   #1
I did an la swap. problem is I did what pocket told me not to do. I cut my old harness before everything was sorted. stereo works, console lights, everything basically works except the horn, heater. compressors not in, but not deleted. can someone help me fix this plz. it's getting cold down south. thankswires from blower
hugdaturns is offline   Reply With Quote
Old 11-15-2017, 09:24 AM   #2
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: need help with heater blower motor wiring
Red wire gets full time power; Should have originally come from the starter post, thru a fusible link, and up to the cut wire shown in your picture.
Black wire is ground for the motor and the relay. Splice an "EYE" at the end of that wire & screw it to the body.
Blue wire: IIRC ( AKA = I THINK! ) is AC signal from the AC pressure switch. Double check to be sure !
So; connect power and ground, then try to turn on the blower.
John in RI is offline   Reply With Quote
Old 11-15-2017, 12:10 PM   #3
thanks so much man. will do asap.
Go Back   Third Generation F-Body Message Boards >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Advertising
Featured Sponsors
Vendor Directory
1982 Camaro '82 || 1983 Camaro '83 || 1984 Camaro '84 || 1985 Camaro '85 || 1986 Camaro '86 || 1987 Camaro '87 || 1988 Camaro '88 || 1989 Camaro '89 || 1990 Camaro '90 || 1991 Camaro '91 || 1992 Camaro '92
All content copyright 1997 - 2014 ThirdGen.org. All rights reserved. No part of this website may be reproduced without the expressed, documented, and written consent of ThirdGen.org's Administrators. We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
