no guage, interior lights, horn or radio, cig lighter
Old May 8, 2018 | 11:49 AM
Vgibson's Avatar
1985 Sport coup Camaro. Carb. Fuse box does not have 2 silver 35 amp fuses, but only one silver 30 amp fuse. Base model car. Can't seem to find problem with why I am getting no lights, power inside anywhere. I get all outside lights working. Even my rear window defogger won't turn on. You can hold the switch, see power, but power does not remain on. Have checked fuses, replaced a 5 amp and a 20 amp fuse. Still nothing. Also replaced the light switch that puts on your out side lights and dims the gauges, even though the other one was brand new. I have removed and looked at all wires inside...nothing seems wrong. I also do NOT have the brain box in mine on the driver side of the car. Only a silver box on RH side of the steering wheel where you find the flasher. Flasher is working fine. Any help please??? I drive my car everyday, and keep it clean and in mint condition. I just got into the car and noticed radio was not working. It is an after market, but PRO installed, and been working just perfect for a few years now, so I know that was OK> I also took the cig lighter apart from the socket and plug...to see if that effected anything. Nope. Still no power. Anyway, any help would be GREAT! I live in a smaller town in Canada, and no one here seems to be able to do anything but rip my car apart and charge over a grand just to look at wires.!! Like whaaat?? I can't afford to have them do that. I have extra pod gauges, one oil and one for temp, but they are working fine. I do a lot of work myself when I can. I am buying one of those power light checkers, but really don't know what to do with that. I am a motor and carb person!LOL I know every nut, bolt and lifter in my car. Can rear lights effect anything? Thank you guys! Cheers, Camaro lover, Vicki.
Old May 8, 2018 | 12:01 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: no guage, interior lights, horn or radio, cig lighter
Check your fusable links at the starter
Old May 8, 2018 | 12:04 PM
Engine: Lb9
Transmission: M20
Power distribution schematics can be found here
http://www.austinthirdgen.org/?pid=19
Power runs from the starter through c100 the connector on the bulk head next to the master cylinder.
http://www.austinthirdgen.org/mkport..._1985_C100.gif
robguitargod1
Mar 25, 2019 05:50 PM
xbazzarex
Apr 16, 2018 01:08 AM
JRobb
Nov 30, 2016 01:34 PM
Lubricant
Nov 14, 2016 05:31 PM
mucker15
Oct 7, 2016 09:40 AM
