TPi injector wiring...
Old Mar 2, 2019 | 11:58 AM
Andy Fanshawe's Avatar
Car: 91 camaro rs
Hi all.
Im just completing a TPi conversion using a fueltech ECU on my 91 RS camaro in the UK.
But Im not sure which is the hot wire connection to the injectors. The pink/black one originally in TPi cars.
If I am looking at each injector from the side of the car (photo attached), which pin is the constant HOT feed? LH one or RH one?
Even my factory manual doesn't show me!
Thanks for any reply.
Andy.
Old Mar 2, 2019 | 12:27 PM
ULTM8Z's Avatar
Re: TPi injector wiring...
pink/black is the hot lead. injectors themselves are not polarized, but the connectors can only go on one way.
the ECM switches the ground on and off to fire them. hot side stays at a constant system voltage off the alternator.
Old Mar 2, 2019 | 12:58 PM
Car: 91 camaro rs
Thank you for the reply.
So I can wire them up any which way I please??!!
I always find this quite weird. Going back to my school days Flemings LH and RH rule says otherwise! But you're the man!
Thank you.
Andy.
Old Mar 2, 2019 | 01:30 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
It doesn't matter which way. but I wire them all the same, whether I use terminal A or B, I keep it consistent for every injector
gta power
Aug 8, 2013 05:12 PM
ttypecamaro
Aug 14, 2007 08:31 PM
Tranny Man
May 13, 2002 04:27 PM
Baldeagle
Jul 23, 2000 10:48 AM
