Alternator?????
Car: 92 Camaro Z28
Alternator?????
Short version: 92 Z-28 305TPI, It will start but then stall out after 30-45 seconds or if I press the throttle. I had a battery charger hooked up and the key on when I heard a very slight Humming / ringing noise in the engine compartment. Found it was coming from the alternator. I unplugged it and she runs. Had a little hesatstion but probably needs to clean itself out. While running I plugged the alternator back in and she stalls instantly. I assume the alternator is back feeding and I think maybe messing with the fuel pump or injectors. Anyone ever have this happen or idea of what's actually happening? Is it a simple change the alternator or could there be an underlying problem.
I put a new A C Delco alternator on 3-4 years ago.
Re: Alternator?????
*Could be one or more , the alternator puts out "3 Phase" AC which is rectified into DC by a set of 6 Diodes , three positive going and three negative going , usually with a final "protection" diode on better built units bringing the total to 7 .
Re: Alternator?????
Unfortunately the AC Delco units are made in China now like everything else. And Powermaster is complete garbage also. Don't get burned by them like the rest of us - I'm down 2 starters and 2 alternators from those jokers. Made in USA - LOL. No they are "assembled" (probably by the blind - nice of them to employ the disabled), from CHEEEEEP Chinese imported components. My last Powermaster was "ringing" with the key off also. Both of their XS Volt alternators I've had died within months. Fortunately I run an Odyssey battery and it just took the abuse like a champ.
We get all our alternators from DC Power Engineering in CA. Check them out. Their online catalog is terrible though so you need to call them:
https://www.dcpowerinc.com/
Bonus - you can have the alt anodized any color you like. Takes about 5-6 weeks to get one though.
GD
GD
Re: Alternator?????
Good luck and good bye dmruski
Car: 92 Camaro Z28
Re: Alternator?????
When people take the time to make a post answering your question , a Thank You may be in order . I have a longstanding policy of never replying again to someone who can't be bothered to say Thank You when I've provided the answer they were looking for .
Re: Alternator?????
You are 100% Correct. I truely do appreciate everyone's input. I cross posted this on another Z-28 forum, and though I put a a thank you out on both but I guess I was mistaken. So thank you all for the input. I had the Powermaster ordered with prime so I was able to make a car show this weekend, however I wrote down the information you guys provided so I can upgrade when this one craps out. So sorry again and thank you all very much.
Cool dude , I appreciate that !
The reason it bothers me when people don't say thank you is that I consider all third gen owners brothers of a sort (or sisters too , Kin if you will) . We are all we have , the rest of the world thinks we're nuts
Re: Alternator?????
GD
GD
Car: 92 Camaro Z28
Re: Alternator?????
Update:
Put the new alternator in Last Friday. Humming is gone but the car still won't run right. It will stay at an idol but any throttle and she dies. I need to stop by my dad's and grab my fuel pressure set but I just put in a brand new Walbro 255. Only about 20 miles on the pump. Anyone have any issues with them? Their supposed to be a good fuel pump but then again I always thought Powermaster made good alternators.
Re: Alternator?????
Update:
GD
Car: 92 Camaro Z28
Car: 92 Camaro Z28
Re: Alternator?????
Pump is good. 45 psi at Idol with the regulator unhooked. Any suggestions anyone???? Idols good for about 30 seconds then surge/dips and if at any point I give it throttle she dies. TPS, MAP both tested good.
Car: 92 Camaro Z28
Re: Alternator?????
I think they run in open loop untill warmup so in theory it should not affect anything untill warmed up. I may be wrong but usually with a bad O2 you just get bad fuel milage maybe small runnability issues. I would also think I should have a CEL if it we're a sensor. But I guess it can't hurt to check. Thanks.
Car: 92 Camaro Z28
Re: Alternator?????
IAC controls the idol. The symptoms would be opposite if that was the problem. It would run with the throttle but not idol. I was thinking maybe the CTS (coolant temp sensor). I know they would go bad in the TBI trucks and cause all kinds of runnability issues. Anyone see/hear of this on the TPI?
Jason M 91Z
06-27-2001 09:33 AM
bad@ss89camaro
06-04-2001 09:38 PM
