B&M Megashifter - Reverse Lights won't work
Old Feb 23, 2020 | 09:25 PM
Wickydooda's Avatar
I'm pretty sure it's wired up correctly. I even went through and redid the wires that were questionably hooked up back when I sucked at electrical. Hopefully y'all can see the picture. The fuse is not broken, I already checked. The reverse lights wont kick on in any gear. The gear selector indicator is damn near perfectly aligned, if that's relevant info. The reverse light bulbs are not broken. It is grounded to one of the nuts on the shifter assembly, as shown in the picture. If anybody can help me narrow down why my reverse lights won't activate, I have a fine reward available.
Also, the (B&M) relay didnt click at all through each of the gear selections nor when I turned the key to the on position.
Old Feb 23, 2020 | 09:53 PM
NoEmissions84TA's Avatar
Re: B&M Megashifter - Reverse Lights won't work
I don't know if this is happening to anyone else, but I can only see the very top of your picture.
Old Feb 23, 2020 | 09:54 PM
Wickydooda's Avatar
I can view it properly (on mobile).
Old Feb 24, 2020 | 06:07 PM
I can see it now.
Old Feb 24, 2020 | 06:24 PM
The only thing I can see from your picture is that orange wire with the black stripe looks like it goes to the steering column area where all those wires are cut.
It appears that it is cut also. Hard to tell though.
Old Feb 25, 2020 | 12:21 AM
Wickydooda's Avatar
Wiring diagram shows that the ORG/BLK wire referenced above goes from the ECU to the Gear Selector Switch, which sounds about considering the context of this post. Will add more detail if I make any progress...
chevycamaro91
Sep 16, 2007 12:29 PM
bulletboy29
Aug 27, 2004 12:35 AM
Kandied91z
Dec 1, 2003 01:05 AM
Dale
Oct 5, 2002 08:57 PM
ip305
Jan 27, 2002 05:58 AM
