Rear Defogger problem
Old Jan 13, 2002 | 06:16 PM
IROCZ28KevinZ's Avatar
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
I think I've almost solved the problem with my rear defogger. I'm gonna replace the switch, as I believe that's one of the problems. I don't see any broken grid lines on the back window, so I guess that's ok. Anyway, you know how there are a series of different-colored wires that connet to the switch in the dash for the defogger. Anyway, there's one wire I can't figure where it goes. It's a thin pink wire with a black stripe. If it's the only thin pink wire with a black stripe in the car, then I found it under the dash. I think it's the right wire. It has a white plug with it, and there's also a thin purple wire in that plug, but that isn't one of the wires that are hooked to the defogger switch. Any ideas on where tha pink wire would plug into?
Kev p.s. check my sig for ino on my car
Old Jan 13, 2002 | 07:28 PM
Jim 86 Bird's Avatar
Car: '89 TA
Engine: LB9
Transmission: M5
its ignition
taken from my shop manual
hope that helps
hectre13
Dec 11, 2023 08:14 AM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Infested
May 22, 2018 11:56 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
