De-coupler Pulleys - for the old school alternators?
Old Mar 9, 2022 | 11:31 AM
82-T/A [Work]'s Avatar
Hey guys... not sure if everyone here knows what this is... but does anyone know if there's such a thing as a decoupler pulley that's available for the 80s GM alternators?
It's something that I installed on my Crown Victoria, and really helps the reliability of both the alternator, the belt, and the accessory system.
Here's a good video to explain how it works:
Long and short... the civilian Crown Victorias didn't come with these, but the Police versions did because of the way they're typically driven. I upgraded my Crown Victoria years ago with most of the performance parts from the police and Marauder variant. The shift from 1st to 2nd, even with 2.73:1 gears at max RPM is just insane. There's so much difference in the belt speed that the pulley squeals for a second, even with all brand new parts (tensioner, and everything in good shape). It's a problem Ford fixed by installing these decoupler pulleys. Just curious if anyone knows if there's any way to retrofit one of these pulleys onto the alternator shaft for our older alternators.
Here is a really good video that shows the difference between using a solid versus an OAP at high speeds...
Aside from the obvious craziness with the belt... the big take-away is that the alternator is not really creating the lag on the motor that it would otherwise be doing at full throttle... so if I understand correctly... you're actually not getting that parasitic loss at WOT over a certain RPM.
Thanks!!!
Steven20063
Aug 22, 2021 07:09 PM
Berlinettaowner
Aug 2, 2018 01:01 PM
savage54
Dec 25, 2016 02:27 PM
hellz_wings
Sep 20, 2013 11:41 AM
Maverick H1L
Dec 15, 2003 11:26 PM
