FS: NIB Cloyes double roller timing set and Proform 2pc timing cover
Car: 1989 Formula 350
Engine: 350 fuel injected
Axle/Gears: 9 bolt w/370 gears
Re: FS: NIB Cloyes double roller timing set and Proform 2pc timing cover
Is this for a 1pc rear main roller cam engine? does it use a thrust washer or needle bearing?
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Is this the type where the top accessing the cam is removible
or the type where the whole cover comes off ( need to remove balancer) leaving the oil pan in place?
Part # ?
Part # ?
1 Post
Car: 87 Vette
Engine: 355/195AFR/SR/219CAM/1.6
Transmission: TH700R4/Vigilante
Axle/Gears: D44/3.45
hi, how can i set that cover with my L98 water pump?
i had similar one and i couldnt tight the pump to the block
because the cover its too thick
its that the same one or a revised version?
thanks
thanks
1992 Trans Am
05-10-2023 07:19 PM
